What causes high nox on smog test?
Old Feb 22, 2013 | 07:48 PM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
My car failed twice because of this high nox thing can some one please help me out? I got it diagnosed and it came back that my egr was bad so I replaced egr and nox reading were higher they went from 700 to 1030?
Old Feb 22, 2013 | 09:27 PM
HottestZ28's Avatar
Re: What causes high nox on smog test?
Nox is from high combustion chamber temps - timing, EGR, engine temp (thermostat). If you replaced the EGR was the passages clear of carbon deposits. Ty to pull up on the diaphragm of the EGR and your engine should die or just about die. If very little to no idle change your passage is carbon blocked. What are your other readings CO2 and HC readings
Old Feb 22, 2013 | 10:15 PM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
Co2 was 14.00 hc is 27
Old Feb 23, 2013 | 09:10 AM
HottestZ28's Avatar
What were the limits. If you test the car colder your co2 and HC will go up but Nox will go down
Old Feb 23, 2013 | 09:24 AM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
I did test it cold
Old Feb 24, 2013 | 06:45 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I did test it cold
You have to have clogged EGR passages. I would pull the plenum and check the passage that runs from the middle of the plenum to the front.
The small runner tube may also be clogged.
Old Feb 24, 2013 | 09:33 AM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
I was actually checking and the vacuum line was disconnected I plugged it up and boom passed the test.thanks fellas
Hotrodboba400
Dec 10, 2019 07:07 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
New2Chevy
Sep 28, 2015 12:35 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
