the cam im want to buy is this ok
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Let's say stock tpi 113 heads 1.52 rollor tip rockers flat tap cam 355 sbc
Comp cam PN 12-364-4
http://m.summitracing.com/parts/cca-cl12-364-4
2500 stall 700r4 3.27 final drive 26 inch tires street car
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: the cam im want to buy is this ok
Barely bigger than stock. Its a pretty safe bet, because with TPI the bigger you got the more you lose out on potential...
Something around 215/215 is probably as high as you'd want to go. The cam you chose isnt a bad choice, but why not go wit ha roller cam? These TPI engines are severely duration challenged. The extra lift and aggressive ramp rates from a roller cam are a really, really good idea when RPM constrained the way a TPI setup is.
Flat tap motor those retro fit cams are more costly and this will be my daily driver
Or this cam its a little smaller but I think it will sound better with the 112 lsa over the 114. Wich will give me more power
http://m.summitracing.com/parts/CCA-12-256-4/
Street Lethal
Apr 30, 2019 12:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
