Edelbrock 3860: worth the cost?
Car: 1991 Z28
Engine: 5.7 TPI
I have a chance to pick up a cheap Edelbrock 3860 manifold. If this is the only mod I were to make to my TPI intake, would it be worth doing- I know the heads are a chokepoint on these engines too-? What if I gasket matched and extrude honed it? What improvement if any would I be likely to see?
Car: 1988 firebird formula 350
Axle/Gears: 2.77
Yes you will feel a difference.
But I would buy large tube runners and port your upper plenum to maximize your gain
And then while your in there you might as well replace your injectors
But yes the baseplate is important for making power with tpi and you will feel a difference
Posted from Thirdgen.org App for Android
sreZ28
Oct 22, 2015 08:21 AM
toronto formula
Sep 10, 2015 07:31 AM
