My Accel intake barely covers the back wall
Old Mar 4, 2013 | 09:40 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I took a picture with the intake in place, and used a marker to draw a line where the intake ends. The next picture shows how much (or how little) of the back wall my intake is covering. Is this just a crappy designed intake? I can see why I've been having leaking issues on the back wall. I'm running the old style AFR heads, but I would think the intake holes on the heads would be in the right place?
Old Mar 4, 2013 | 11:30 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: My Accel intake barely covers the back wall
That looks 100% normal to me.
Old Mar 5, 2013 | 12:10 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Looks pretty good to me. Just use a larger bead of some high quality rtv to seal it up. I have a leak back there too. On the list of things to do.
Old Mar 5, 2013 | 03:05 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
100% normal. Use permetex sensor safe ultra black.
Don't run the motor for atleast 24 hrs after you install the intake.
Old Mar 5, 2013 | 03:48 AM
conlinj's Avatar
The right stuff worked well for me, sets up fast though.
-Jim
Old Mar 5, 2013 | 04:11 AM
tpi88camaro's Avatar
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
^^^ What he said.
The Right Stuff is the best stuff i've found for sealing up both ends of my intake. Sets up fast and when it fully cures you will need a prybar to get that intake off.
Old Mar 5, 2013 | 10:22 AM
Car: 89 GTA
Axle/Gears: 4.10
Roger that, thanks, makes me feel better about this intake.
You can see my dimples I made with a 1/8" drill bit. I guess I'll have to move them a little bit to match where the intake sits. The goal of them is to give the silicone bead something to bite on.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
