esc location
Old Mar 9, 2013 | 06:16 AM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
esc location
Ok I read its on the cowl and but mine dones not have it there. I think I found it by the brake booster, but this other TBI TA has both one 3 prong on cowl and 1 5 prong on driver side.
Old Mar 9, 2013 | 08:40 AM
kimberanton's Avatar
Car: 89 IROC-Z28 Camaro
Engine: 350 TPI IROC
Re: esc location
thats it, driver side firewall with relays on a bracket that bolts to the firewall
should be 3 relays; mass air flow relay, burnoff relay, and fuel pump relay
Old Mar 9, 2013 | 08:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: esc location
The small flat box with 5 pins is the ESC filter. The one with the 3 pins mounted on the bracket is the MAP sensor.
RBob.
Old Mar 9, 2013 | 01:39 PM
Sojer's Avatar
Re: esc location
Ok thanks the last part I need. I can't stress enough how much I appreciate you guys help on TGO thank you.
bigjay89gta
Oct 15, 2015 08:04 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
meeklay812
Oct 1, 2015 03:46 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
