evap. canister question
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: evap. canister question
What? You need to post up more. You've had 25 members look at your thread and have not replied. Now, there are a couple different types of evap solenoids. You need to post up a picture so that we can visually see what you are talking about. When a picture is up, when there is a discription of the engine and vehicle, then I'll proceed to help you out man. I have diagrams that may help you out.
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
That's supposed to have a dust cover on it or a hose that runs in towards the fender area. It vents into the air. I wouldn't plug it. Will probably build up pressure.
Car: check
Engine: check
Transmission: check
It should only suck air while CCP purge is in affect. Which is not at idle. There is a flag in the calibration to set whether the solenoid is NC or NO. It may be reversed.
Typically, purge is enabled once over a set MPH, TPS, and MAP threshold.
RBob.
RBob.
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i just capped it off at tb. car never ran better and it got rid of my surge problem.
Car: check
Engine: check
Transmission: check
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
