Fuel rail modification.
Old Mar 17, 2013 | 11:19 PM
chris884117's Avatar
I know this subject has been brought up before but i have a different question regarding this.
So they have the fittings and such you can use to run the fuel lines in the back of the fuel rail (cold start) to clean up the front of the motor. But i was wondering is there any reason i cant just un bolt the fuel rails and spin them 180* and plug the 9th injector port?
Old Mar 17, 2013 | 11:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel rail modification.
Your dizzy would be in the way not to mention the clearance notches in the rails for the runners may not clear so you would need to grind on them. Why don't you just tap the return for 3/4 npt and drill and tap the regulator for 1/4 npt and buy a adapter for the ninth injector feed .
Old Mar 18, 2013 | 11:38 AM
Thats proly what ill end up doing. I just have everything pulled apart right now anyway to clean/paint/upgrade everything/rebuild. So the thought crossed my mind as it appeared to be a simple switch.
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
