Will LT1 Heads Bolt to an L98 block?
Old Mar 18, 2013 | 02:00 PM
Demonic13's Avatar
Car: 1991 Chevrolet Camaro 25th Anniv.
Engine: 5.7L 350 TPI
Simple question, probably answered before. I can seem to find the answer in a search.
My l98 has 160,000.00 miles on it. I think my head gasket is bad causing to much pressure in my radiator causing them to blow.
I would like aluminum heads. I don't care if there used as long as they bolt up. Cant find the corvette L98 heads.
Here is the catch I need need SUM-G9005 shorty headers to bolt up and the HSR I have
Intake:
http://www.summitracing.com/parts/wnd-7540
Fuel rail kit:
http://www.summitracing.com/parts/hl...-172/overview/
Kirban billet afpr
http://www.kirbanperformance.com/pro...R+%236547.html
To bolt up to them as well. Any suggestions? Any for sale? Let me know. Thank you.
Old Mar 18, 2013 | 02:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Will LT1 Heads Bolt to an L98 block?
Lt1 heads need to be modded pretty extensively to bolt and work with L98 blocks.
Not really worth it imo. Unless you could port and weld by yourself
Old Mar 18, 2013 | 02:28 PM
Demonic13's Avatar
Thank you so much I will stay away from them. Do you have any suggestions though? Like ones that will be aluminum and bolt up to the parts I have. Thank you.
Old Mar 18, 2013 | 02:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Any aluminum head for standard sbc will work. Any as in your typical 23 deg 175-210cc style heads. Hsr will need to stick with a sub 200cc for the smaller 1205 gasket size
Old Mar 18, 2013 | 02:49 PM
Demonic13's Avatar
Do you have link an Ebay link or something, like would:
http://www.ebay.com/itm/New-Flo-Tek-SBC-Chevy-Aluminum-Complete-Assembled-Cylinder-Head-Straight-Plug-/261183844554?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ccfc530ca&vxp=mtr
Work? they say only 180cc but you suggest 200cc would that be a major problem?
Old Mar 18, 2013 | 03:02 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I stay away from ebay most of the time. Too many cheap products out there
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
355tpipickup
Aug 25, 2015 12:54 AM
TheExaminer
Aug 19, 2015 10:07 PM
