I've got an 89 Corvette and I'm building a mild 355 for street cruising. I was thinking of the Lingenfelter 211/219 cam. I wrote Lunati and their pick for a cam was the 20080721. It's specs are 219/227 .549 .565 112 lsa 106 icl I'm running a mildly ported stock tpi intake, 22# injectors, edelbrock 60879 heads, 1.6 roller tips, and 10.7:1 compression. Any thoughts?? I think the lunati might be a bit much. Trans is a built 700r4 with 2500 stall and 3.07 gear.
How about this way..? Is there a better cam than the lpe 211 for a street setup using the stock but slightly ported tpi intake?
Building a similar setup, but with a 5 speed.
Went with comps suggestion, 08-501-8, don't have it together yet, so can't reasly say how good it is.
