TB hoses
Car: Today? 98 GMC Sonoma
Engine: Seriously? The Sonoma has a TPI 305
Axle/Gears: 7.625/4.10
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TB hoses
Top is the PCV system supply to the rocker cover.
Lower is the vac port for the line coming from the charcoal canister purge valve
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TB hoses
If you install a vented breather cap in your passenger side valve cover you can plug the upper fitting.dont forget to plug the bottom little ported vacuum signal since you are not using a egr valve.
Re: TB hoses
I seen the little one too, but forgot to ask about it. Thanks!
Pac J
May 17, 2020 10:44 AM
