8.8 Grade bolts
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 8.8 Grade bolts
The 8.8 has a tensile strength of 116,000 psi (pound per square inch). The grade 10.9 is used where high strength is required. The 10.9 grade bolt is rated at 175,000 psi.
You can use the 8.8
You can use the 8.8
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: 8.8 Grade bolts
I'd say, you could bolt the runners to a truck and use it in truck pulls.
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
