Programming VATS out?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Programming VATS out?
if the vats is bypassed in the programing you will have injector pulse but no starter enable. jumper the 2 larger gauge wires on the enable relay usually yellow and purple or green and purple. You can also ground the relay on the lead from the pass key module. This is more of a electrical question than diy prom.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You have changed nothing as to the module reading the key correctly or operating ( or not ) the starter relay so if any of the physical components or wiring are bad you will still have problems
