LB9 will only start cold. Won't start warm.
Old May 11, 2013 | 05:35 PM
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
Any theories? I can start it up and it runs and drives as well as it ever does, but when I park it and try to start it again ten minutes later, nothing. Fuel related?
Old May 11, 2013 | 05:43 PM
Engine: 305 LB9
Re: LB9 will only start cold. Won't start warm.
And to clarify, the starter works perfectly, the engine will just spin and spin, nothing happens.
Old May 11, 2013 | 05:48 PM
Engine: 305 LB9
Also I havent put the fans back in the car. But I doubt its temperature related, because I drive it just around the block, park it and it wont start. Not long enough to get super hot... When I try to start it again, I smell gasoline fumes...
Old May 12, 2013 | 07:25 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
check your CTS
Old May 16, 2013 | 06:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by penguinpanda0
it wont start..
Pull the engine codes to see if any faults showing
Old injectors leaking fuel maybe , filling the cylinders up with gas?
When it sits over night the fuel evaporates away so you get a clean cold start with no excess fuel
Old May 26, 2013 | 03:41 PM
Engine: 305 LB9
It doesnt take a full day for it to start again,so I'm not so sure.
Just put the fans back in and fixed a big water leak. Didnt do anything. Should probably replace thermostat, its at least ten years old.
To give more details, I drive it around the block, and park it. Go to start it again, it spins, then fires briefly as if it was going to start normally, but then just immediately dies. After that, any attempt to start it just makes the engine spin and spin, occasionally catching a little.
Its fuel related it seems, I know I'm getting spark.
Old May 26, 2013 | 04:18 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
If you let it set for a minute then try to start it with full throttle and it starts, probably flooding, several causes. minor flooding can be cleared by throttle wide open which allows more air into motor. Let off throttle as soon as it starts though Another option is to pull spark plugs when it wont start and check for any that are wet with fuel.
Old May 26, 2013 | 05:13 PM
Engine: 305 LB9
With full throttle it will start, but will die immediately... Maybe it is flooding?
Old May 26, 2013 | 05:51 PM
Engine: 305 LB9
If I try to start it with the throttle half way depressed, it will start, and run (somewhat badly) so long as I have the throttle depressed for a little while. After that I can let it go back to closed. So that means that I'm flooding, and that my injectors are bad, yes?
Old May 26, 2013 | 11:02 PM
danclemts's Avatar
Sounds like it, but since injectors aren't cheap, better to verify. Need to get a fuel pressure tester and see how fast you lose fuel pressure. I think there is a tech article on doing this. AutoZone has fuel pressure testers in their loan a tool program.
Old May 27, 2013 | 11:08 PM
Engine: 305 LB9
Think I could get away with just doing the O rings for the injectors? I mean the injectors themselves seem to work, the car runs and drives well enough, it just floods...
Old May 29, 2013 | 12:06 AM
danclemts's Avatar
Orings won't affect leaky injectors. o rings just seal them to manifold. the leak is most apparent when car is idling and not using much fuel`. You can let it idle for 30 seconds, then pull plugs and see which are wet to narrow it down
Old Jun 16, 2013 | 07:32 PM
Engine: 305 LB9
Replaced my 02 sensor and Coolant Temp Sensor (both 12 years old(yikes)) and that solved my problem... Thanks guys! (=
Old Jun 16, 2013 | 07:57 PM
southbay08's Avatar
You might want to check the resistance on the injectors when they are hot.
More often than not that is when the coil fails. Just another thing to rule out.
Anything below 12ohm should be replaced.
Old Jun 25, 2013 | 06:57 AM
perfectcircle75's Avatar
Just had the same problem with mine. Car has 58000 miles and never thought it could be the injectors...but i was wrong. I had 3 that tested out hot at under 4 ohms and 1 under 10. Definately test them, you can save yourself alot of time. I also bought bosch ones from southbay. Worked perfectly
Orr89RocZ
Apr 25, 2016 08:28 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
86Base
Aug 8, 2015 01:34 PM
