EGR Solenoid
Old May 19, 2013 | 10:28 AM
cmierobf's Avatar
Car: 1989 Firebird Formula 350
EGR Solenoid
Does anyone know of a source for a new EGR solenoid 89 350 TPI or a way to adapt the LT1 EGR solenoid..? Or looking for a working used replacement EGR solenoid. Mine has multiple intermittent faults based on scanner results; engine starts but quits under cold load in gear. Restarts and code clears most of the time.
Old May 19, 2013 | 10:48 AM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: EGR Solenoid
I don't know anything about the LT1 EGR solenoid, but you can find an 89 Firebird solenoid on ebay or possibly your local parts store. If you don't want to take the gamble on ebay, you can always try Rockauto.com or some other well established online auto part stores.
http://www.ebay.com/sch/i.html?_odkw...enoid&_sacat=0
Old May 19, 2013 | 12:50 PM
82tarecaro's Avatar
Re: EGR Solenoid
The LT1 solenoid works in reverse so it will be opened instead of closed and vice versa. Member Jeckylandhyde did a write up on using a Cadillac EGR solenoid. I will find the link.
Old May 19, 2013 | 12:52 PM
82tarecaro's Avatar
Re: EGR Solenoid
Here you go...
I think this also might work for the older cars like the Crossfires. I was going to give it a shot as my solenoid looks like it has seen better days.
http://s9.zetaboards.com/nythirdgen/...7236770/1/#new
Old Jun 29, 2013 | 10:55 AM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Re: EGR Solenoid
http://www.ecklerscorvette.com/corve...1985-1990.html
Old Jun 29, 2013 | 11:32 AM
TURBOJOE's Avatar
Re: EGR Solenoid
Napa #CRB 22307
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
