dmdonjuan
close
- Join DateJun 2001
- Locationseattle/Kirkland wa.
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car500,000 mi. 89 Iroc,t-tops.
- Engine383 stroker,chipped,msd ign, tpi.
- Transmission700r4 rebuilt
- Axle/GearsLS1 front brakes, 2002 ls1 rear 342
- Liked:0 Times in 0 Posts
Driver side each injector is 22 ohms. Passenger side 16 ohms. Anybody else seen this or know why??? Fluke 89, yes I can use it. Original injectors, 89 tpi 350. 350k miles.
Quote:
There is NO WAY you have original injectors in an 89 car, with 350k miles.Originally Posted by dmdonjuan
Driver side each injector is 22 ohms. Passenger side 16 ohms. Anybody else seen this or know why??? Fluke 89, yes I can use it. Original injectors, 89 tpi 350. 350k miles. They simply do not last that long. My OEM injectors were 17.1 ohms,
dmdonjuan
close
- Join DateJun 2001
356,000 miles. Original Red paint that still shines, and YES WAY.Originally Posted by the blur
There is NO WAY you have original injectors in an 89 car, with 350k miles.They simply do not last that long. My OEM injectors were 17.1 ohms,
I own of the few original owners remaining. If your not the original owner, your injectors were replaced. They do not last with the E10 fuel.
dmdonjuan
close
- Join DateJun 2001
Looking for an answer about the ohms on my injectors. And for "the burp" there's an E-10 free station close to my house that i use.FYI.
Quote:
22ohm? are you sure?Originally Posted by dmdonjuan
Driver side each injector is 22 ohms. Passenger side 16 ohms. Anybody else seen this or know why??? Fluke 89, yes I can use it. Original injectors, 89 tpi 350. 350k miles. Member
Quote:
dumbjuan with the 383, tuned motor, and you have OEM injectors. Originally Posted by dmdonjuan
OEM injectors were never 22 ohms, They were 17.1 ohm. Learn how to use a DVM.TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,156 Times in 755 Posts
^^^ I really don't think name calling is a thing to be doing on this board.
I have seen the factory 89-92 injs hang on for 300,000 miles.
It CAN happen but its stupid rare.
Quote:
correct, but notice his comment above, and then he deleted his post. But I happened to quote his comment before he deleted it.Originally Posted by TTOP350
^^^ I really don't think name calling is a thing to be doing on this board. . TTOP350
close
- Join DateOct 2001
- LocationIl
Quote:
Well he needs his pp smacked to I guess.Originally Posted by the blur
correct, but notice his comment above, and then he deleted his post. But I happened to quote his comment before he deleted it. dmdonjuan
close
- Join DateJun 2001
To busy for smackin, just want to know why the resistance would go up, on all 4 injectors and only 1 side. And for blur, you get !
