Dead fuel pump or something else? In urgent need of help
Old Jun 4, 2013 | 09:54 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
Recently my car decided not to start, it just cranks. When turn the ignition to prime the pump, instead of priming for 3 seconds and stopping it tries to constantly prime and doesn't stop. There's also quite a loud audible hiss in the engine bay. Here's a video of the problems. I've tried replacing the fuel pump relay with no luck in fixing it. Anyone have an idea of what exactly is wrong?
Old Jun 4, 2013 | 10:02 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Dead fuel pump or something else? In urgent need of help
Do you actually have any gas in the tank ( real , not going by the fuel gauge )
Typically noise when the lines have air in them instead of being full of fuel
Old Jun 4, 2013 | 10:04 PM
Axle/Gears: 3.45
You could be right, my gauge says it's got a little but I haven''t been driving it, just turning it on occasionally and letting it idle while I do work on it, I'll fill her up with bit of gas and see what happens
Old Jun 4, 2013 | 10:36 PM
Axle/Gears: 3.45
I put more than enough in there, still no luck. the hiss in the engine bay/lines sound a little more bubbly like it's got a little more gas but not a huge difference. Could it be a clogged fuel filter?
Old Jun 5, 2013 | 12:17 AM
Axle/Gears: 3.45
I tried unplugging the ecm while it was priming and it stopped. is this a sign of a faulty ecm?
EDIT: there's definitely fuel getting to the engine, I left the key on while it primed and pressed the pin in the schrader valve and gas sprayed up
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
