removing smog pump and egr
Car: 1988 iroc-z
Engine: 5.7 tpi
Transmission: 700 r4
If I remove the smog pump and egr on a stock 5.7 tpi 1988 camaro will it create any problems and what would be the benefit?
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: removing smog pump and egr
you are gonna need a custom chip to correct it. You are going to get a code 32 for egr and removing the smog pump will throw off the o2 a little bit.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Its not worth pulling your air pump for minimal unnoticeable gain. But yes you may get a malf 32 and when the air pump is commanded on the o2 mv adjusts so it should be programed out.
backtothe80s
Sep 5, 2015 12:39 AM
