Fuel Injector Fitment
Car: 87 Camaro Z28
Axle/Gears: 4th Gen 3.42
I was wondering if these fuel injectors will fit my 87 camaro tpi 305 need to change them because i was given 24lb injectors and its dumping to much fuel
http://www.ebay.com/itm/300878289808 or
http://www.ebay.com/itm/350809624305
thanks will apreiciate the input.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Injector Fitment
Engine: Lb9
Transmission: M20
Those second injectors look like the have been soaking in varnished fuel for the last decade in a bone yard
Car: 87 Camaro Z28
haha yea thats what i was thinking
but how about fitment of these injectors i just need to get the 24lb out of the 305 and have a temp fix till i get the moneey for the newer ones from southbay
Engine: Lb9
Transmission: M20
They will fit in your tpi but ford 0280150943 is rated at 19 at 37 psi on a ford. But at 43.5 psi you will still run rich they will flow 22#hr.
Those injectors "BE NASTY"
They will fit without a problem. We actually have the same ones in stock, however they will be in better condition then the ones you are looking at and they come with a 3 year warranty.
New2Chevy
Oct 4, 2015 11:27 PM
Firechicken86
Aug 12, 2015 10:07 PM
