Fuel Rail Mod
Old Jun 6, 2013 | 09:33 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Fuel Rail Mod
Looking to do the fuel rail mod to get rid of the hard lines on the front of the rail. My issue is I went to tap the front of the pass. rail the pressed fitting started to spin. I am going to have to build it up so I can tap it for an 3/8 NPT fitting. My question for people that have welded these rails, what filler material should I be using?
Mods: not sure if this is the right section as It has to deal with fab'ing and TPI. Move if necessary. Thanks.
Old Jun 6, 2013 | 09:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Rail Mod
Why don't you just remove the restricter plug and go 3/4 npt ?
Old Jun 7, 2013 | 08:46 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Fuel Rail Mod
3/4 NPT is way too big.
Here is what I did. I cut the fuel line off the front of the rail, made it flush and drilled it to tap for a 3/8 NPT fitting. As I started to tap it, the plug broke and started to spin within the bore of the rail. I am now left with a hole that I can tap for a 1/2 NPT, but the 1/2 NPT is too large and the threads will break through the top and bottom of the rail.
What I am going to do is ream the hole and place a piece of bar stock into it. Then I want to weld the stock to the rail to seal. Next I will drill and tap the stock for a 3/8 NPT fitting.
I want to know what kind of material the rail is made out of so I know what filler rod to use.
Old Jun 7, 2013 | 10:29 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Fuel Rail Mod
If you are going to be welding to the stock rails may as well just weld a -AN fitting of your choice direct to the rail
Old Jun 7, 2013 | 10:31 AM
88Trans-am's Avatar
Car: 88 GTA Trans-am
Engine: 350 vortec TPI(in process)
Transmission: 700-R4
Axle/Gears: 3.27 LSD
Re: Fuel Rail Mod
Your fuel rail is made from aluminum. It would be better if you tig welded the stock in as it is cleaner than mig.
Otherwise grind it or have a machine shop clean up the ends before you still and tap the lines.
Keeps everything nice and clean.
Cheers
Old Jun 7, 2013 | 10:49 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Fuel Rail Mod
What grade of aluminum filler? 4043, 5356? Yes it will be TIG welded. Depending on what grade of aluminum the rail is made out of (6 series or 4 series) will bias my decision on filler.
Old Jun 7, 2013 | 10:56 AM
Engine: Lb9
Transmission: M20
Re: Fuel Rail Mod
Remove the restricter, it is a press in fit with a o-ring seal. I apply heat with a torch. Sorry you are correct it is 1/2 npt.
Old Jun 7, 2013 | 11:00 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Fuel Rail Mod
[IMG][/IMG]
I measured and it looked like the 1/2 NPT tap is larger than the rail at its thinest points. So it wont work for me.
Old Jun 10, 2013 | 08:09 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Fuel Rail Mod
So no one knows what filler rod to use when welding the fuel rail?
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
