88 Formula 350 - Wont start without carb cleaner and runs rough
Old Jun 19, 2013 | 10:38 PM
wwe442's Avatar
Car: Too many!
I just picked up an 88 Formula 350. It starts really hard unless you spray some carb cleaner in, then it fires right up. Also, it runs a little rough, almost like the cat was clogged. I took the cat off tonight and only a few things fell out, but otherwise it was fine (looks like it was hollowed out). I didn't really run it long enough to see if the cat was the issue since my neighbors would shoot me running something that loud at 11 pm. Anyways, what else could it be? Injectors or throttle position sensor maybe? Thanks!
Old Jun 19, 2013 | 11:25 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 88 Formula 350 - Wont start without carb cleaner and runs rough
is it just on cold start like not enough fuel ? Bad csi !
Old Jun 20, 2013 | 01:39 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by wwe442
it runs a little rough ,what else could it be?
Pulling the codes is always the 1st thing to do when you have problems with on a computer controlled engine
Old Jun 22, 2013 | 05:33 PM
89RS305TTops's Avatar
Car: 87 Camaro Z28
Engine: LB9
Transmission: 700-R4
If it only starts on carb cleaner, you've got a fuel issue. Your going to have to start backtracking. See if the fuel pump is coming on, does it have enough volume? Fuel filter may be clogged, if those are fine you can move forward to the injectors and regulator and check them. Pulling the codes might help but these computers are very basic and probably will just tell you that you have a fuel issue, which is obvious lol
Posted from Thirdgen.org App for Android
Old Jun 23, 2013 | 10:44 AM
wwe442's Avatar
Car: Too many!
Thats what I figured it was, something with fuel. If I remember correctly the codes were 22, 34 and 42 or something like that and they were the throttle position sensor, something with the map sensor, and not enough oxygen.
Old Jun 23, 2013 | 10:46 AM
wwe442's Avatar
Car: Too many!
And of you start it cold with the carb cleaner it runs fine, but if you go to start it again within a few hours it runs like crap and wants to stall. The guy said he did just put a new fuel pump on though
Old Jun 23, 2013 | 01:31 PM
southbay08's Avatar
Old Jun 28, 2013 | 10:52 PM
wwe442's Avatar
Car: Too many!
Originally Posted by southbay08
She starts a lot better now, no fluid needed! It runs a little rough though, sounds like it has a vaccum leak behind the plenum
Frozer!!!
Jan 19, 2024 04:55 PM
okfoz
Mar 9, 2017 02:35 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
Sherpajames
Aug 7, 2015 06:56 PM
