Losing pressure, inline check valve??
Car: 86 IROC-Z
Engine: 355
Hey guys. I have replaced my fuel pump in the tank on my 86 355 TPI Camaro twice in the last couple years, and am losing pressure again in the pump or pulsator in the tank. I really don't want to pull it again!! I was looking into putting a check valve inline somewhere. Maybe at the flex lines, or the lines coming out of the pump. Has anyone done this?? Any ideas on ways to adapt my fitting to AN to make this work?? I have found a check valve in summit that has -6 AN fittings. Any ideas would be much appreciated!
Thanks!
Thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Losing pressure, inline check valve??
The pulsators are junk. its better to use a piece of fuel resistant hose in its place.
Car: 86 IROC-Z
Engine: 355
Engine: Lb9
Transmission: M20
with a resisidule pressure check valve im sure the fpr would bleed back to the tank .
Car: 91 RS / 91 Z28
Engine: HT383 / Stock TPI 350
Transmission: T-5 / Stock Auto
Axle/Gears: Stock, open / Stock, with True Trac
Engine: Lb9
Transmission: M20
The fuel pump dampener purpose is for sound dampening noise to quiet the fuel pump noise from being transferred into the fuel hard lines.
Car: 91 RS / 91 Z28
Pictures say a thousand words! Thanks for going the extra mile!
backtothe80s
Sep 5, 2015 12:39 AM
R3500
Aug 17, 2015 12:16 PM
