who sells a good adjustable fpr
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
is there anyone that knows a good all around adjustable fuel pressure regulator?
I know there are some vendors on here and I'd like to stay in the community and support someone on the forum...Thanks
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Re: who sells a good adjustable fpr
I use the Holley AFPR, been on the car for 6/7 years now with no problems.
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Try doing a search for Kirban, that's what I run on my HSR. No problems with it for several years now.
http://www.kirbanperformance.com/Bui...R+%236547.html
Car: 91 GTA
Axle/Gears: 3:73
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Ive been running a tpis for about 4 years. No problems at all.
Axle/Gears: 3:08
thanks guys,I have had TPIS suggested to me before and have never heard of Kirban so yeah I'll check that out.I also have run a holley before but it failed to adjust out so I returned it and put my stock one back in but now I need to replace my diaphragm and it's just as much to get an afpr with one as it is just to buy a stock one...Thanks again guys
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Get the diaphragm from South Bay fuel injectors for the stock fpr, They have the best deal I have seen. No need to spend more money on a afpr when your engine doesn't need it.
http://m.southbayfuelinjectors.com/p...7&product=3054
Axle/Gears: 3:08
Axle/Gears: 3:08
Axle/Gears: 3:08
well I replace the regulator diaphragm and the fuel filter.Its still not going over 30psi so I guess I'll start researching how to change the fuel pump..
Car: 91 GTA
Axle/Gears: 3:73
Axle/Gears: 3:08
well I pulled the tank tonight..Any input on a pump to put in?I'm thinking just a stock AC delco unless you guys have any suggestions
Car: 1991 Formula Firebird WS6
Engine: 350 SB TPI
Axle/Gears: 3.23 Stockers
AC Delco, I am happy with mine! DO NOT get a friggin Airtex.. I have had my Formula for 2 months and went through 3 Airtex. I got to the point I cut an access door under the carpet I was going through them so fast. Luckily they were free, but got tired of changing them. My Delco has been in a month and as soon as I put it in I noticed an immediate difference! Car fired quicker cold and fuel pressure was much more stable.
Axle/Gears: 3:08
Axle/Gears: 3:08
Axle/Gears: 3:08
Axle/Gears: 3:08
Engine: 4++,350 & 305 CIs
Pulsator dampens the pulsing psi the pump makes. Helps keep the fuel psi more stable.
Engine: 350 SB TPI
I removed mine and put 3/8 fuel hose in its place with no problems.
I have submersible EFI hose in place of mine as well.
Axle/Gears: 3:08
Ok so this is no big deal but I was wondering about something.I can get an edelbrock or a Russell fuel pump that comes with the strainer and other stuff for like 30 bucks more than buying the delco and strainer seperate...is there any advantage to that?it says the edelbrock flows at 67gph,idk what the stocker flows at..just a thought
Axle/Gears: 3:08
pump install complete!and I am so glad haha.car runs much better now.I just have to get the exhaust rewelded in place and I should be good to go as far as running that is..Thanks for all the advice guys
86IROC112
Aug 17, 2015 02:00 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
