91 305 PROM
91 305 PROM
Hi guys,
This has probably already been answered but I want to make sure I have the right PROM in the ECM to do a swap to speed density. Does anyone have a serial number of what it would be? I have DELCO AXXB 3063 and another number is 973089213600115. I'm not exactly sure what's what but before we take the car apart I wanted to make sure I had the right chip.
Any help would be great. Thank you!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 91 305 PROM
Axxb is a speed density memcal gm p/n 16163062 . it is for a 305 lb9 tpi, MD8 A/Trans .
designed for QPE 215/60R16 Tires, QMT 235/55R16 Tires and contains vats enabled.
Re: 91 305 PROM
Thanks so much. Any ideas about the knock sensor? I called GM and they told me there were 2 for the LB9 so I'm confused now. Thanks again!
Engine: Lb9
Transmission: M20
Re: 91 305 PROM
ACDELCO Part # 213-91
{#10456019}
SENSOR,KNOCK BUTTON TYPE TERM-1/4-18 THD; Iroc-Z
It is a 3.9k ohm sensor
{#10456019}
Engine: Lb9
Transmission: M20
Re: 91 305 PROM
If you need the vats disabled or any other reprograming send me a pm I can assist you with the swap
Hotrodboba400
Dec 10, 2019 07:07 PM
