Are these the right injectors?
Old Jul 31, 2013 | 11:45 PM
Hurban96's Avatar
I ordered a set of new bosch 3 22lb injectors from FIC for my 90 corvette. I received these today and they don't look like the new bosch 3 design.
Old Jul 31, 2013 | 11:51 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Are these the right injectors?
Your right , not bosch 3's. They look like Lucas. You should have gone with the thirdgen vendor southbay
Old Aug 1, 2013 | 10:43 AM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Those look like ones I just installed in one of my Corvettes, replacing the Multec injectors.
Jon @ FIC said the new design (like you have) is more tolerable to alcohol in fuels today. I believe they are made by Delphi. Call him and ask, but my car runs AWESOME with the Delphi injectors vs. the old Multecs from Rochester.
Old Aug 1, 2013 | 11:31 AM
Hurban96's Avatar
I talked to Jon and he said these are the new stainless steel Delphi's. Direct replacement and have a 5 year warranty. Im gonna give them a try
Old Oct 1, 2021 | 07:40 AM
icecold's Avatar
Car: 1990 formula
Engine: 350 tpi supercharged
Transmission: 700 r4
I do not have a fmu, the Paxton kit did not have one.
im running around 6 psi boost and used tunercat to modify the prom slightly for fueling.
being about 18 years ago and many laptops since I really have no idea where it sits but as I remember it ran pretty good with no codes.
I just figured that after this many years sitting in my garage it is likely the injectors are gummed up and at a minimum need a good cleaning.
but if there are better injectors now why not just swap them out to avoid any issued
Old Oct 1, 2021 | 11:48 AM
southbay08's Avatar
What is the part number on the injector?. Just an FYI....most injectors are all fuel compatible and have stainless internals. Yes if injectors sit they are more likely to gum up....has nothing to do with the tolerance of the fuel. Old stock multecs in our opinion should be swapped out with newer injectors....they will eventually fail at some point or another. Keep us posted
dfarr67
Aftermarket Vendor Review
Jul 15, 2014 08:01 PM
cjvdbeek
Aug 9, 2011 11:21 AM
OUTATIME GTA
Oct 13, 2006 05:03 PM
grndmasnightmar
Oct 6, 2004 05:21 PM
KustomIroc
May 7, 2003 02:35 PM
