HEI vs EST ??
Old Aug 7, 2013 | 09:41 PM
BadRiggins's Avatar
Car: 1989 Pontiac Firebird Trans Am
Engine: 5.0 305 V8 FI
Transmission: 700R4 Automatic
HEI vs EST ??
How do I know what distributor I have, in my 1989 Trans Am w/ 305tpi.
Old Aug 7, 2013 | 10:14 PM
Chad85T/A's Avatar
Car: 85 T/A
Re: HEI vs EST ??
If its all factory it'll have the est type. The 89 has the small cap with the coil separate of the dist, the electronic hei has a big cap with the coil on top and a 4 wire plug on the passenger side of the body, a vac advance hei looks just like the electric hei only it has a vacuum pot where the 4 wire connecter is on the electronic hei.
Old Aug 7, 2013 | 11:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: HEI vs EST ??
All are versions of the GM HEI (High Energy Ignition) Dist;
the electronic version used for EFI engines ( the only type you can use with a factory computer ) is known as a computer controlled HEI;
hence the 4 wire plug underneath that connects to the ECM and EST.
L98GTA87
Oct 19, 2015 10:43 PM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
pacoelrapido
Sep 11, 2015 02:41 PM
