200r4 tv cable on tuned port
Old Aug 10, 2013 | 07:07 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Engine: 355, roller, Profilers, FIRST tpi
Transmission: 200r4
Howdy, gents. Was wondering if I need a geometry correcting bracket for a 1988 TPI unit like the one I had to get for my Speed Demon carb. I am guessing no due to the fact that 7004R's came in these cars from the factory and its basically the same system. Am I right? Thanks.
Old Aug 10, 2013 | 07:16 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 200r4 tv cable on tuned port
https://www.thirdgen.org/forums/tech-general-engine/663243-complete-your-profile-information.html
The TPI TB has the correct hookup for a 200 or 700 TV cable
Old Aug 11, 2013 | 01:10 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
I assume that means that the throttle linkage has the correct amount of "pull" and at the right rate given any point in the arc of its movement for proper TV cable function.
Old Aug 11, 2013 | 10:54 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The TV cable mounting bracket and the linkage give the correct pull;
assuming you are using a TPI cable, not one from a TBI or carb setup
post # 24
https://www.thirdgen.org/forums/tran...-too-fast.html
Old Aug 13, 2013 | 06:37 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
post # 24
Perfect. I kind of figured it was good to go but when its so easy to fry a 200r4 or 7004R with an improperly set up TV cable, better safe than sorry.
Thanks.
L0tuS
Oct 4, 2015 08:07 AM
customblackbird
Oct 1, 2015 04:30 PM
eustodp
Sep 20, 2015 05:09 PM
m00n420
Sep 11, 2015 02:39 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
