a quality replacement fuel pump
Old Aug 15, 2013 | 10:01 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I have a 86 TPI Camaro. after 7500 miles my fuel pump got eaten by this alcohol fuel crap. the question is; where do you all buy your fuel pumps? who has the best one in regards to quality construction? im at the moment considering a "bosch" brand from NAPA. and a "wix" brand fuel filter. but I would like some input from other TPI owners as to what and why you buy for your cars
Old Aug 15, 2013 | 10:08 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: a quality replacement fuel pump
My vote is for the Acdelco ep241
Old Aug 15, 2013 | 10:52 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
X2 on the Ep241. Found a good deal on Ebay for these a while back.
Old Aug 16, 2013 | 07:57 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
I'm running a BOSCH 69218 in my 85 from Rock Auto. Very quiet and probably have about 8k miles on it without any issues.
Old Aug 22, 2013 | 10:45 PM
Schrade's Avatar
Did you do a static fuel pressure test with the pump, that the alcohol got a 'grub-on' with?
What were the results?
Old Aug 23, 2013 | 01:34 AM
IROZINCO's Avatar
2nd the Bosch. Not made in china neither. I got 2 bad OOTB AC Delcos when i went to replace mine......
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
