TPI Prom question?
TPI Prom question?
Long story short, my tbi efi in my 86 c10 crapped out and I want to use my tpi unit to get it back up and running.
Tpi info:
fully ported lower stock manifold
ported slp runner
fully ported plenum matched to the slp's
Painless stand alone harness
maf ecm with abwn prom code
the engine is a stock tbi 305 with a 700r4
My question is, will this prom be fine running this setup? or will I need a different prom?
Tpi info:
ported slp runner
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI Prom question?
The abwn is for a 350, you need to use a memcal for a 305 or have your reprogramed.
the fueling and timing is different between a 305 and 350 .
Engine: Lb9
Transmission: M20
I would run what's right , If you want a dip socket soldered in and a 305 calibration on a second eprom send me a pm I can assist with that .
Sanjay
Aug 12, 2015 03:41 PM
