SLP runners w/cold start injector on 1991 plenum?
Old Aug 17, 2013 | 03:45 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I have a set of SLP runners with the cold start injector hole that are made to fit 85-88 engines. I am putting them on a Edelbrock vortec lower and a 1991 upper plenum. Other than the cold start injector block off plate, what else needs to be done to run these runners with the 1991 upper?
Where does the hole in the intake manifold go to? Does the passage itself get blocked or just the opening in the runner flange?
SLP runners w/cold start injector on 1991 plenum?-mtigmd9l.jpg
Does the passage in the top of the runner need to be plugged as it doesn't get blocked off by the upper plenum?
SLP runners w/cold start injector on 1991 plenum?-tnsq2z2l.jpg
Old Aug 17, 2013 | 04:14 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: SLP runners w/cold start injector on 1991 plenum?
tap the top vacuum port IIRC 1/4 npt make the head flush or lower on the ninth injector hole use a block off kit from ebay or a 3/4 expansion plug IIRC.
Old Aug 17, 2013 | 06:19 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Thanks once again!
Old Aug 17, 2013 | 06:53 PM
Engine: Lb9
Transmission: M20
Np, you can measure the vacuum tube and use silicone aroun a expansion plug as well, I'm nit sure but I'm thinking it was 3/8. The injector passage to answer your question goes down under the manifold were the huge npt plugs are and gets feed into each intake runner passage through small holes in the intake runner.
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
mdtoren
Aug 16, 2015 05:45 PM
