Plenum/runner gasket help
Car: 1990 Iroc
Engine: 305 tpi
Hey guys, I'm in the process of replacing the injectors in my 1990 Iroc, and I'm beginning to reassemble everything. The only problem I've run into so far is trying to remove the old gaskets from the runners and plenum, they're stuck on there pretty good. Anybody have any tips/tricks to make the process a little easier? Thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Plenum/runner gasket help
its called gasket remover lol, actually soaking the parts in warm water or used engine oil will help penetrate the gasket meterial once you pull what you can especially the crush inner gasket meterial.
Car: 1990 Iroc
Engine: 305 tpi
