Strong fuel smell in exhaust and plenum
Old Aug 31, 2013 | 03:12 PM
ETX's Avatar
ETX
Car: 1987 Iroc Z L98
Engine: L98 L31 Vortec Crate with TPI
I had a strong fuel smell in my exhaust and code 25 MAT sensor. I took the plenum off end the plenum was damp and smelled or raw fuel???
The car has 48000 miles and still has the factory fuel pump and injectors.
I have read that the FPR can be the problem...mine is a TPIs AFPR with only about 8000 miles on it.
Any thoughts?
Old Aug 31, 2013 | 11:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Strong fuel smell in exhaust and plenum
I took the plenum off end the plenum was damp and smelled or raw fuel???Any thoughts?
Pull the vac line from the AFPR to the intake off and check / smell for fuel.
If the diaphragm in the reg is split it allow raw fuel to go straight into the intake from the reg through the vac line
Very carefully , no ignition sources
With the hose disconnected from the intake end and a rag underneath it , turn the key on to prime and see if any fuel comes out the line.
code 25 MAT sensor.
If the MAT , located in the bottom of the plenum was covered in fuel it may not be performing correctly , hence the code
Old Sep 1, 2013 | 09:35 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://www.southbayfuelinjectors.com...Diaphragm.html
Here is the temperature vs ohms chart that applies to the mat/cts
Old Sep 2, 2013 | 06:09 AM
ETX's Avatar
ETX
Pulled the vacuum line and turned the key. No fuel came out.
Can the diaphragm have a tear yet no fuel come out the vacuum line?
eightsixseven
Dec 16, 2024 01:50 PM
TheExaminer
Aug 26, 2015 04:59 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Winchester1094
Aug 18, 2015 10:23 AM
