Steal braided fuel line ?
Old Sep 1, 2013 | 05:11 PM
87irocZ28Crush's Avatar
Car: 1987 Iroc Z28
I did a single belt conversion on my 87 305 tpi and made new braided fuel lines to take place of the metal ones that no longer fit. My question is, what Russell fitting should I use to adapt it to the stock metal ends and the rail ends? I gong think that the flared make and females will make a tight seal. Anyone done this yet?
Thanks,
Keith
Old Sep 2, 2013 | 08:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Steal braided fuel line ?
If the hardlines have Saginaw ends on them, likely need two of each of the following:
9894DBH Female 14mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
9894DBJ Female 16mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
Be sure to double check the hardline end sizes. Never know when GM changes stuff throughout the years. The 14mm would be for the return side, while the 16mm is for the feed side.
RBob.
Old Sep 2, 2013 | 08:55 AM
Car: 1987 Iroc Z28
RBob.
Thanks Rob. Just what I was looking for.
Keith
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
