injectors ohm good,But can they still be bad
Old Sep 14, 2013 | 03:13 AM
n2deep22's Avatar
I have 88 iroc 350 tpi runs rough wont idle hesitates when reving and poping in intake. I have my suspicion that it is in the injectors tested them and they all ohmed out good 16.8-17.0 so my question is can they ohm out good but still be bad? if that makes sense.
Old Sep 14, 2013 | 07:38 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: injectors ohm good,But can they still be bad
Of course an injector coils can be good and the nozzle could be clogged ot leaking.
You need to do more checks. Popping out the intake could be a valve timing problem such as a worn cam or chain.
Old Sep 15, 2013 | 03:16 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Makes perfectly good sense. I just had one do this on my old Acura Legend. It had developed a miss. Resistance in spec, clicking, no internal leakage.
The only way I found it was during a pressure drop test. It wasn't passing the same amount of fuel as the other injectors.
The injector was new, three years old with only 29k miles on it.
Old Sep 16, 2013 | 07:40 AM
southbay08's Avatar
Yes, injectors can fail even though they all ohm out fine. Problems occur depending on the condition of the injector itself. They could clog and leak.
Dirt can have an affect on the spray pattern and can cause them to flow out of spec which will affect your performance.
specialized
Jun 18, 2022 09:26 AM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
twest2k2
Aug 24, 2015 11:26 AM
justin57
Aug 20, 2015 07:05 PM
