need some help picking fuel injectors
Old Sep 26, 2013 | 09:37 PM
mike22115's Avatar
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
im building a 350 with vortec heads (2.02 valves) withe a comp xfi 268 cam. also have a HSR with a adjustable fuel pressure reg. but i dont know what injectors to choose, some people have said 24lb will do just fine others say no less than 27?
im thinking the 27's. what happens if i put to big of injectors in?
if you need anymore info on the build to help me out just ask
Old Sep 27, 2013 | 01:42 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: need some help picking fuel injectors
24#hr will work fine or even going up to 27-30 you will be ok. you will need to tune for it though. You can use the 24s at 3 bar and increase the fuel pressure but the best way to get the best air fuel ratio is datalog and tune. if you need any assistance or pointers send me a pm.
Old Sep 27, 2013 | 10:12 PM
southbay08's Avatar
bryan623
Mar 22, 2021 06:43 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
