odd driveability issue...
Old Oct 1, 2013 | 04:31 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
OK, so I finally got the engine back in and running in my GTA. T56, 350 TPI, mostly stock with bolt ons and some porting. I just finished swapping in fresh lifters, plugs and wires, roller rockers, timing, putting correct injectors in it (will end up with some new bosch ones when I get paid) etc... It's been interesting to get it to this point to say the least.
So I get it driving and almost immediately I notice it's temperamental when it's hot out. I've been having a few codes: MAF too high, CTS too low, ESC error are the recurring ones. I had a fluctuating coolant temp sensor so I swapped it for a known good one and it went -38 degrees on me. I checked my grounds at the engine and they are OK so I figured it was the ECM.
Changed my ECM. No change.
It acts like a bad ignition module when it's hot; it will sputter, run rich, hesitate, stumble and backfire with poor power and driveability. What I found odd was if I shut the engine off and immediately restart it, it will run fine for a few minutes before it does it again which makes me think twice about replacing a GM ignition module. Anyone see anything this odd before?
Old Oct 1, 2013 | 08:03 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: odd driveability issue...
U check the IAT? Believe it shares the ground with CTS.
Old Oct 1, 2013 | 09:15 PM
dhirocz's Avatar
It does and I checked it. No dice. Also did a circuit integrity check. Checked out ok
Mark_ZZ3
May 24, 2018 01:02 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Stryker412
Sep 20, 2015 06:59 PM
Fronzizzle
Sep 8, 2015 12:10 PM
lakeffect2
Sep 7, 2015 03:52 PM
