OEM mass air flow meter $1000
Old Oct 15, 2013 | 12:25 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
ok,im on my 7th mass airflow meter from auto zone.some new ,some rebuilt.same deal, sooner than later, a code 34 will appear .and the car wont run till I unplug it. I am using the FSM trouble tree and the only thing failing is the meter.where do you guys get your MAFs at?? everything checks out otherwise.and it runs beautifully when the light is off ,which hasn't been much lately.the ONLY code stored is 34. could I be overlooking something ?? any ideas??
Old Oct 15, 2013 | 01:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: OEM mass air flow meter $1000
Seems odd to have that many failures. You may have other issues causing that but not sure what? At this point i would talk to tequilaboy and look at going ls1 maf or similar with modded chip code and signal converter or going speed density
Old Oct 15, 2013 | 01:42 PM
Guest
Guest
Posts: n/a
Stop shopping at junk-a-zone, problem solved. That will be $999.99
Old Oct 15, 2013 | 07:01 PM
racerx520's Avatar
Go to a normal parts store, my t/a took a Bosch MAF, which was $600 (used in vettes), i paid for it at a reputable store and havent had a problem in about 60k miles
I got a starter from them once, long story short, after 3 start ups, it never worked again, so i went to napa, and that one is still in it
Old Oct 15, 2013 | 10:38 PM
Guest
Guest
Posts: n/a
You paid -$600- for a USED maf...I paid $1xx for mine brand new.
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
