700r4 tranny slipping
Car: 34 ford
Engine: 1986 camero tuned port
Axle/Gears: ?
hey guys
tranny was slipping,so took it to tranny shop.they showed me a cable that moves with the throttle cable,and goes to the tranny.it was slipping.so he showed me how to re ajust it by advancing to full throttle and pushing a button on the cable,to bring it back to where it should be.this worked fine for a week or so ,but now it is slipping again.
has anyone had this problem?anyone know what that cable is called,so I could order a new one.? thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 700r4 tranny slipping
The tv cable gm part numbers
In 85-88 it's 25521263, in 89-92 it's 10163879
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
hey guys
Car: 34 ford
Axle/Gears: ?
May be too late if some internals fried, but this is worth a try. Guaranteed to get TV cable properly set: https://www.thirdgen.org/forums/tran...ms-solved.html
Car: 34 ford
Axle/Gears: ?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
