88 plenum vacuum barb replacement?
Old Nov 10, 2013 | 04:45 PM
bphage's Avatar
Car: 1988 IROC-Z Convertable
Engine: 350 Cam, Heads, Heders...etc.
Transmission: 700-r4 "Raptor"
I have changed over to MAP on my 88 and I don't want to tap the plenum after looking at it more carefully. So what I want to do is "y" the vacuum port to the fuel pressure regulator and feed it to the MAP sensor; but to minimize any vacuum fluctuations I would like to replace the small barb that goes to the FPR with a larger barb. I was thinking a barb similar to or even bigger than the barb that feeds the rest of the vacuum lines in the car would work well. Does anyone know where I can find a vacuum barb that will screw into the plenum that is larger?
Old Nov 11, 2013 | 05:56 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 88 plenum vacuum barb replacement?
Why not connect the MAP to it's own dedicated port and Y the reg off the HVAC line coming from the other port?
Take the fitting to a engineering or plumbing supply shop.
They usually have a range of brass fittings of a certain thread type but for varying hose sizes.
Old Nov 11, 2013 | 11:06 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Here's an idea:
The tooling hole for the plenum is just about the size for a 1/8NPT fitting (it's slightly bigger than the recommended tap drill size, but I had no issues with getting good threads).
Make a vacuum passage into the plenum with an 1/8" diameter drill in the bottom of the tooling hole (it's already pointed so you'll get a nice on-center hole), thread the tooling hole with a 1/8NPT tap and install your barb fitting.
(The photo shows a vacuum source for a vacuum gauge).
specialized
Jun 18, 2022 09:26 AM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
