stalls at operating temp, no codes
Old Jan 13, 2014 | 05:41 PM
  #51
armygreen87's Avatar
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Transmission: 4-speed automatic
Axle/Gears: 2.77
Re: stalls at operating temp, no codes
Did some more listening and the noise I hear is more of a suction noise and it's of course just the intake sucking air thru the air duct, silly me. I took the MAF off to examine it and what I saw is pictured and attached. No engine codes so this may not be an issue but the crack at the bottom of the ring doesn't look to be there on purpose as it was not a straight crack. The Upper one looked like it was on purpose, perfectly straight. Only thing from auto zone that's on this car is the sparkplug wires. I hated to get them there but my fav store didn't carry 8 mm and I didn't want to special order. The hot temp problem is gone it seems. Found a fan switch harness broke, flushed coolant system and it no longer gets hot. Replaced CCV a couple weeks ago, the PCV too and found that input to the intake from the PCV hose was hand loose. Tightened it. I think it helped some.other new parts are the complete distributor assembly and ignition coil. TPS, IAC, sparkplugs and wires done late spring. I will check out the intake gaskets and see what I find. I will try to readjust IAC and TPS also. If it gets down to those spark plugs (which aren't but maybe 500 miles on them) then I'm replacing these headers while I'm at it. Big pain in the butt to get to those plugs and the headers leak exhaust anyway. Recommendation on some headers that will give me better clearance, yet last?
Attached Thumbnails stalls at operating temp, no codes-20140111_175723-1.jpg
Old Jan 13, 2014 | 11:12 PM
  #52
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Yeah that housing looks broken to me. Could have unmetered air coming in causing a lean condition
Old Jan 14, 2014 | 02:17 PM
  #53
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
Ok I will change the MAF. Damn, they have gotten more expensive since my last iroc
Old Jan 14, 2014 | 03:12 PM
  #54
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
How much? I have to check mine. It has that lower panel with the 5 wire leads on the bottom missing. I am wondering if that covers seals the unit. If not I have vac leaking wire the wire leads go to the into the MAF
Old Jan 14, 2014 | 03:53 PM
  #55
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
Last time I checked oreillys had it for around $125. ABC Auto probably costs more, autozone just not dependable but probably only $5 cheaper anyway lol. I might order mine online for cheaper. May not have warranty though so that's the catch. A few years back I could get one for about $100 so they are getting harder to come by I bet. Might as well do MAF delete but would probably spend more money going that direction
Old Jan 14, 2014 | 05:19 PM
  #56
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
Turns out it's $125 at autozone and $160 at oreillys. The more I studied this MAF, that crack looks like it's made that way. The ring is two halves and that's where the halves meet and are screwed together. If someone else could pull there's off to confirm this that would be cool. Going back to the intake and looking for leaks...Anyone know much about the EGR solenoid? I know you can't buy them new or refurbished anymore and have to convert to another and change wiring harness. What symptoms does it normally give when it's bad? Mine is missing the little filter and not sure how long it's been like that
Bubbajones_ya
Jul 6, 2024 08:32 PM
amcnellis
Sep 16, 2015 04:16 PM
86IROC112
Sep 11, 2015 04:04 PM
64goatman
Sep 9, 2015 01:09 PM
