91 Trans Am Missing and No Start After Warm
Old Nov 22, 2013 | 05:53 PM
Procharged281's Avatar
Have a 1991 305 Trans Am. It starts and runs great... After approx 15-20 mins. it starts to miss and the drivability becomes very poor. After shutting off, it will not restart. The car has only 9,000 miles on it. It's home is in a collection which is stored in a climate controlled garage. The fuel is brand new 93 octane. Fuel pressure is within specs, the spark is there... But no go. It will however fire up (roughly) with a spritz of starter fluid... It's as if once the ECM kicks in after warm up, it goes to hell. I forgot to add that this happens every time.. Runs great cold... Turns to hell when warm/hot.
Attached Thumbnails 91 Trans Am Missing and No Start After Warm-image-4029999237.jpg
Old Nov 22, 2013 | 09:51 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Re: 91 Trans Am Missing and No Start After Warm
Next time it doesn't start disconnect CTS (front of engine beneath throttle body) and then try. If it starts might first try changing the CTS sensor. If same problem persists after changing CTS you might then try checking injectors impedance. Should be around 16ohms.
Old Nov 23, 2013 | 09:52 AM
Okay. I already tried disconnecting CTS.. Didn't work.. But I did do what you suggested and ohmed the injectors with a Fluke 333 meter. The readings ranged from 3.9 to 16.5. I'm under the impression that the injectors are shot.
Old Nov 23, 2013 | 10:00 AM
MrPackstin's Avatar
Car: 1989 GTA
Obviously 3.9 is bad. Good meter for sure. Replace all injectors, Multecs are notoriously bad. SouthBayInjectors on here has a good price on sets and an excellent service plan on their Bosch III injectors. I think if you mention thirdgen your get 10% off.
Jorlain
Aug 24, 2022 05:11 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
mustangman65_79
Aug 8, 2015 12:07 PM
