vacuum line
Old Nov 23, 2013 | 05:56 PM
kboy's Avatar
Car: 89 Formula 350
Engine: 5.7
Transmission: auto
vacuum line
Well I got my new Bosch III injectors in today. But when I was done I was checking out the vacuum lines and notices the one that comes from under the plenum and over the valve cover and behind the ac evaporator can isn't connected to anything or it came off of somewhere. Does anyone know if this is just a vent line or if not where its supposed to connect to. Thanks for any info.
Old Nov 23, 2013 | 08:42 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: vacuum line
Might be the one that goes to the heater valve ?
Under plenum one goes to egr solenoid down under the coil.
I put bosch 3's inn last week also, car runs as smooth as silk now.
Where you at in NJ ?
Old Nov 23, 2013 | 11:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vacuum line
https://www.thirdgen.org/forums/tech...formation.html
Old Nov 24, 2013 | 07:47 AM
kboy's Avatar
Car: 89 Formula 350
Engine: 5.7
Transmission: auto
Where's the heater valve located. Mine should be same as yours considering its an 89 5.7. I just can't believe it came off somewhere that easily. I wasn't yanking on it or anything. The line used to have a little piece of black tape holding it to another line right by the coil. Can you snap a pic. I'm located in Howell. Where are you at.
Old Nov 24, 2013 | 04:10 PM
kboy's Avatar
Car: 89 Formula 350
Engine: 5.7
Transmission: auto
Re: vacuum line
ok figured it out after looking at the emission picture under the hood. It was the line that goes to the bottom of the throttle body. I must have pushed it out of the way when I was taking everything apart and just forgot about it. At least it was an easy thing to take care of.
Old Nov 25, 2013 | 07:30 AM
Car: 90 Iroc Vert
Engine: 5.0L
Re: vacuum line
Hey I'm down in Franklinville (Glou Co).
They make vac line couplings / splicers - at Pep Boys in the help section stuff.
Just a pc of hose slides over the outside.
Old Nov 27, 2013 | 07:53 PM
kboy's Avatar
Car: 89 Formula 350
Engine: 5.7
Transmission: auto
Re: vacuum line
Yeah your way south. Im up in Monmouth. I just had to fish that line back under the plenum and connect it to the throttle body, so it was an easy thing to take care of.
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
