tpis flow booster tpi
Old Dec 20, 2013 | 07:42 PM
Terrence1725's Avatar
Car: 1988 Trans am GTA
Engine: 5.7 tpi
Transmission: auto
Axle/Gears: 3.27 posi
Hey guys in about an hour I'm gonna order a flow booster for my tpi it's 33.95 free shipping is it worth it? It goes on the front of the throttle body to flow air better I think they are also called air foil hurry for those who have had them
Old Dec 20, 2013 | 07:47 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tpis flow booster tpi
Comes with a bottle of snake oil hp booster for christmas save your money
Old Dec 20, 2013 | 08:00 PM
Engine: Lb9
Transmission: M20
http://www.ebay.com/itm/CAMARO-FIREBIRD-THROTTLE-BODY-AIR-FLOW-BOOSTER-FOIL-85-97-L98-LT1-TPI-CFM-NEW-/231120019064?pt=Motors_Car_Truck_Parts_Accessories&hash=item35cfd39e78&vxp=mtr
If your determined to get one same same but cheaper.
Old Dec 20, 2013 | 08:46 PM
Engine: 5.7 tpi
Transmission: auto
**** for 25 bucks I'm gonna try it I think if it helps I'll post if it don't I'll still post and sell lol
Old Dec 20, 2013 | 10:44 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Don't bother , we already know the answer
Maybe you should save your $$$ and read this 1st ;
http://temp.corvetteforum.net/c4/vader86/minormods.html
especially the notes at the bottom about Things that DON'T WORK
Old Dec 21, 2013 | 12:23 AM
Engine: 5.7 tpi
Transmission: auto
Dang I ordered before I seen the posts I'll put it on and find out might as well already spent the 25 I'll sell it to my friend that swears by them if it don't work lol
Old Dec 21, 2013 | 03:03 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Some people swear the air foil works...some people say its a waste of money. If you want it use it.
Old Dec 21, 2013 | 03:44 AM
Engine: 5.7 tpi
Transmission: auto
Thank u 86 I'm gonna start posting pics of my car soon as I figure out how lol
Old Dec 21, 2013 | 12:14 PM
Car: 91 Trans Am
Engine: 355 TPI
I'm going to warn you you won't feel a difference in the "butt dyno". There is a general list of first mods to do to try and open these engines up.
I usually host through photo bucket. Its easy. You can only attach so many pics to the board but with photo bucket you can post all the pictures you want
Old Dec 21, 2013 | 01:57 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
What all do u have done to the car right now over stock besides the air foil ??! Mabey we can come up with some better mods that u will actually feel an improvement over stock !!
Old Dec 21, 2013 | 03:02 PM
Engine: 5.7 tpi
Transmission: auto
Ok well it all started when I bought my GTA for $1600 about 5 months ago when I went to look at it the I pull in the guy runs up and starts it I could hear a wineing sound thinking oh its the belt came to mind well everything sounded good so I paid cash got gas this thing ran like crap due to sitting for 3 years so I get gas then drive about 22 miles to do an oil change I wanted to do it before he started the car but to late there was maybe a quart in my poor 5.7 tpi changed the oil ran great for about 5 hours then got rod knock pulled rebuilt it .40 over flat top pistons mild cam the shop doing the work said they put a 400 crank in but have no way to confirm it runs great now I can spin my 245/50/16s "just put new 255s on there yesterday" anyway I can smoke em threw my auto 700 r4 threw 3rd so my mods as of now a manifold back exhaust no cat into a cherry bomb pro series muffler sounds great stock intake set up with k&n round filter msd street fire coil New msd cap and rotor New plug wires with plugs 180 thermostat air foil coming I'm stuck on where to go now
Old Dec 21, 2013 | 03:08 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Try using some of these........ to make your posts easyier to read.
If they 'put a 400 crank in there' they would have also changed the pistons and you would have a 383. This would also require some tuning of the ecm.
What are the specs for the mild cam? TPIs are picky about cams.
Did you get any recipts, or a list of what parts were actually used in the rebuild? How much did it cost?
Old Dec 21, 2013 | 03:11 PM
Engine: Lb9
Transmission: M20
Dataloging and the injector size tells a story as well.
Old Dec 21, 2013 | 03:28 PM
Engine: 5.7 tpi
Transmission: auto
For the motor build cost 2100 it just says performance rv cam see the fright company they had me ship my motor with misplaced my motor for 3 weeks it was sitting in the wrong shop so they gave me a discount and they said they would throw in some extra goods what they say and have done could be a different story all I know is my car idles around 450-500 rpm and runs great
Old Dec 21, 2013 | 06:17 PM
Car: 91 Trans Am
Engine: 355 TPI
If you have a stock tpi manifold I would do runners and port the base and plenum. Then a decent set of headers.
Old Dec 21, 2013 | 07:46 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If you believe all the seller claims out there there is 500p to be gained with $10 bolt-ons
As observed in the sticky at top of page
https://www.thirdgen.org/forums/tpi/...-also-tps.html
The seller on the air foil is not lying , it does improve airflow as proven by tests
Stock TPI/LT1 48mm Throttle Body w/o airfoil -- 783.0 cfm
Stock TPI/LT1 48mm Throttle Body w/ airfoil -- 821.9 cfm
but if your TB is not a power restriction now , increased available airflow will not help it any ;
given a 350 ci engine @ 6K can only suck 600 cfm
Old Dec 21, 2013 | 09:04 PM
Guest
Guest
Posts: n/a
The air foil has been proven to -ONLY- gain--->2WHP<---
Old Dec 21, 2013 | 11:01 PM
Engine: 5.7 tpi
Transmission: auto
Ok so will the air foil help with what I've got? And should I port the runners and stuff myself or have someone do it? And if anyone can post a do it yourself link for porting? Pics and step by step instructions would be amazing..
Old Dec 22, 2013 | 03:05 AM
Car: 91 Trans Am
Engine: 355 TPI
Porting the stock runners is pointless. There's isn't enough metal to make them any bigger. You need a set of SLP runners. Port them. Match the plenum and lower manifold to the runner port size. You can port at home. Just take your time
Old Dec 22, 2013 | 03:17 AM
Engine: 5.7 tpi
Transmission: auto
Where can I get slp runners and what do they run price wise?
Old Dec 22, 2013 | 02:38 PM
11ellswray's Avatar
Car: 1986 Camaro Z28
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
http://www.summitracing.com/parts/sle-20002
MAY not be exactly what you need. Read all descriptions very carefully and if you can't figure it out ask
looks like 317 bucks roughly
Old Dec 22, 2013 | 02:52 PM
Engine: 5.7 tpi
Transmission: auto
Would I have to do a 9th injector delete?
Old Dec 22, 2013 | 04:12 PM
Car: 91 Trans Am
Engine: 355 TPI
Those runners have a 9th injector provision
Old Dec 22, 2013 | 04:19 PM
Car: 91 Trans Am
Engine: 355 TPI
They can also be found here http://www.lmperformance.com/brand.a...ords=20&sort=p
That one is for cars without the 9th inj
And this is for cars with the 9th inj
Old Dec 22, 2013 | 05:45 PM
Engine: 5.7 tpi
Transmission: auto
It just sent me to a blank page every time I clicked it? Are they worth 300?
Old Dec 22, 2013 | 06:36 PM
Car: 1971 Camaro
Engine: 427
If you have a built stroker with a decent cam, yes you definatly could use sone ported slp runners, or a stealth ram for that matter.
You really need to find out what's inside that block.
Old Dec 22, 2013 | 07:05 PM
Car: 91 Trans Am
Engine: 355 TPI
The links are working for me. I plan on going to a HSR eventually to ditch the long runners
Old Dec 22, 2013 | 09:05 PM
Engine: 5.7 tpi
Transmission: auto
They are now and why HSR set up?
Old Dec 22, 2013 | 10:12 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
why HSR set up?
https://www.thirdgen.org/forums/alte...gal-whats.html
http://www.gmhightechperformance.com...hird_gen_iroc/
Old Dec 22, 2013 | 10:58 PM
Engine: 5.7 tpi
Transmission: auto
Aww I see lol
Old Dec 22, 2013 | 11:55 PM
racerx520's Avatar
i love how "The Tornado" is in the stuff that doesn't work lol.
LT1Formula
20
Nov 14, 2015 12:02 AM
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
