Idle air adjustment question
Old Jan 2, 2014 | 09:53 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I've read the procedure for adjusting the minimum idle air adjustment in the tech articles. When jumping the A and B terminals at the DLC with a paper clip, waiting 30 seconds then disconnecting the IAC connector and then start the engine, do you leave the paper clip in the DLC before you start the engine or do you remove it before you start the engine? The tech article doesn't say to leave it in or take it out. Thanks.
Old Jan 3, 2014 | 11:18 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Idle air adjustment question
Take it out then start the engine and set the min idle speed.
Old Jan 3, 2014 | 05:44 PM
jermdm's Avatar
Car: 1989 Iroc-z
Thanks for the help. Wasn't forsure and I didn't want to hurt anything.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
redmaroz
Aug 16, 2015 11:40 PM
perZ
Aug 15, 2015 01:17 PM
