04 5.3 with tpi setup?
Old Jan 4, 2014 | 05:15 PM
tazz6989's Avatar
Car: 86 Iroc z / 91 RS
Engine: LB9 / looking for a bbc 396
Axle/Gears: 2.73 both for now
can i put my TPI setup on a 04 5.3 and use my SD harness and ecm
i have been given a 5.3 that needs to we reworked outta a 04 z71
i dont need people to tell me that just go with the ls set up i dont have the money for the wiring/computer ty
Old Jan 4, 2014 | 05:27 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Hahahahhaha. Not even close. Completely different animal. Aside from the jokes, that is not even an option. Sorry
Old Jan 4, 2014 | 05:37 PM
tazz6989's Avatar
Re: 04 5.3 with tpi setup?
ok so i know i wanna get the 305 outta here but i dont have the money to go ls and i would like to go with the flow of the vortec heads best way to go about it i was thinking a 96-2000 vortec 5.7 block with a lt4 hotcam port the heads get the slp runners port them aswell with the vortec intake am i wrong
Old Jan 4, 2014 | 06:12 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
You cannot use any of your TPI Gen 1 stuff on the motor you got.
The truck intake is real good for the street they make good torque. They already have long runners....which actually move some air! Flip your intake upside down and take a look at them
Some headwork, headers tune and a mild cam (even a used z06 cam) will really wake it up
Editops missed youre staying with the non lsx block
Old Jan 4, 2014 | 06:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Do a
Plenty of Vortec head engine builds documented on here.
port the heads
Porting Vortec heads is not recommended ; a little cleanup at best
read
https://www.thirdgen.org/forums/tech...mods-info.html
Old Jan 4, 2014 | 06:38 PM
Axle/Gears: 4.11
Porting vortecs-better really know youre stuff or youll go backwards every time. It can be done but not for the person just learning
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
