Fuel injector question
Car: 89 firebird
Engine: LB9
Hi all,
I am new to the third gen....just recently acquired an 89 formula, with the lb9 tpi engine.
I noticed a fuel leak at the fuel rail cross over tube....and as I have it all torn apart now...to address that.
I noticed that I have two different types of injectors.
It has 4 5156. 5235186.....Internet searches lead to believe these are for a v6 model
Then the other set is 1237 17102119.....the search here says that is old part number...but the correct injector.
So to the real question....are those other injectors going to cause a problem?
Thanks!
Thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel injector question
http://www.autozone.com/autozone/par...ier=79645_0_0_
http://www.fuelinjector.citymaker.co...99/4699485.htm
5235136 are Multecs, toss the. All in the garbage and get these.
http://www.southbayfuelinjectors.com...ebird-305-tpi/
You can definitely run injectors that have 2 different part numbers, however they need to have the same flow rate and the same spray pattern. There are many injectors that have a different color and part number yet they flow the same. IMO you should just replace all of them.
Car: 1991 GTA
Engine: LB9
While you have it apart, you may as well replace all of them.
Once upon a time it was ridiculously expensive to replace injectors.
Now that we have Southbay providing high quality injectors at fantastic prices, there is no reason to just replace a couple at a time.
Car: 1988 Trans Am GTA
Axle/Gears: 3.73 posi
Im looking at getting new injectors i have a 88 305 and i may be putting a 350 in what injectors would be good to buy?
Car: 89 firebird
Engine: LB9
I see you offer 3 kinds of injectors for this engine.
I hope this isn't a dumb question...but how do they differ?
Thanks again!
And thanks for the other replies!
I am definitely going to replace all of the injectors.....as I have no idea how old they are.
Firechicken86
Aug 12, 2015 10:07 PM
