MAF vs MAP SD Pros and Cons?
Old Feb 5, 2014 | 06:59 PM
tazz6989's Avatar
Car: 86 Iroc z / 91 RS
Engine: LB9 / looking for a bbc 396
Axle/Gears: 2.73 both for now
can i get away with more on the MAF then the MAP SD
when camming etc?
Old Feb 5, 2014 | 08:35 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: MAF vs MAP SD Pros and Cons?
Assuming that the question is cam without tuning, then yes MAF can self adjust within reason. MAP will get messed up more easily with a cam change.
I did a cam swap on a MAF TPI and the car runs awesome on the stock tune. It stinks at idle, but at any other speed it's just wonderful.
Old Feb 6, 2014 | 05:29 AM
tazz6989's Avatar
ok sounds good i have 3 cars 1 87 iroc thats parts a 91 RS witch i was making SD but will go carb now and just got a new member of the family a 86 iroc that needs paint and a lil love under the hood as in clean up payed 500 for it so ill keep the TPI in the 86 and carb the 91
Old Feb 13, 2014 | 01:48 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
F.I. 57 Belair
Aug 23, 2021 01:09 AM
BumpaD82
Feb 26, 2016 02:57 PM
3.8TransAM
Sep 17, 2015 02:16 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
scotrans am
Sep 5, 2015 04:26 AM
