weird fuel pressure problem, bad pump or regulator???
Old Feb 9, 2014 | 05:11 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
Yesterday I had a problem where my 91 z (305 tpi) wouldn't rev past 3000 then wanted to stall out. so, I posted the symptoms here:
https://www.thirdgen.org/forums/tpi/...ml#post5712113
got some feedback and started working on it.
Today, a whole new set of problems (which is why I am doing a new post about it). Now it no longer has the symptoms of my original post and will hardly run at all.
key on engine off it I get 20 psi then drops to 0.
do above the second time, get the same thing.
car will start, cranking time is normal. running fuel pressure is about 20-25.
if I pull the vac line off the fpr, no change.
if I pinch the return line while running, it shoots over 60.
If you look at my original post from yesterday (link above) you can see how the problem started.
I am thinking it is a bad fpr. does this make sense? is it possible a bad fpr damaged my new pump?
Old Feb 11, 2014 | 12:22 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
Re: weird fuel pressure problem, bad pump or regulator???
been a couple day; anybody got any suggestions on this?
Old Feb 12, 2014 | 01:06 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd definitely feel the FPR is bad, (as TP mentioned in your original thread).
Old Feb 12, 2014 | 07:28 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
Got a new fpr today. I'll let you know if that was the problem. (might be a couple days before I can swap it out though)
Old Feb 13, 2014 | 01:22 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
