Aluminum head bolts
Old Feb 15, 2014 | 01:30 PM
racerx520's Avatar
Aluminum head bolts
anyone know what i should torque these to? i have a haynes manual, but i cant find it and i'm not sure what i should put aftermarket aluminum heads at. also does it matter what kind of head gasket i got? a friend who works for a local Napa got me a regular 350 head gasket, wasnt sure if it had to be a specific material for aluminum.
Old Feb 15, 2014 | 02:19 PM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: Aluminum head bolts
you are supposed to torque them to per the head bolt manufactures rating regardless of the head material or gasket. i believe ARP recommends 80ft/lbs where as my service manual states 77ft/lbs for stock bolts
the head gasket does change with cylinder head material. some gaskets dont like aluminum heads
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
355tpipickup
Aug 25, 2015 12:54 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
