lunati 20080543 cam
Car: 1984 drag car and 1991 Z28 street
Engine: 406sbc
Transmission: powerglide
Axle/Gears: 5.14
lunati 20080543 cam
Anyone out there use Lunati cam 20080543 / 54743LUN in a 350 TPI?
Considering it along with the vortec head. Will be used in street/ strip camaro.
Dyno results? 1/4 mile?
thanks!
- Advertised Duration (Int/Exh): 287/298
- Duration @ .050 (Int/Exh): 219/227
- Gross Valve Lift (Int/Exh): .471/.480
- LSA/ICL: 112/108
- Valve Lash (Int/Exh): Hyd/Hyd
- RPM Range: 1800-6000
thanks!
Engine: 406sbc
Axle/Gears: 5.14
Re: lunati 20080543 cam
I did buy this cam used, locally. Didn't get it installed yet however, but trying it soon.
Still hoping someone else could share some results in the mean time
