19lbs injectors or bigger?
Car: 1988 Trans Am GTA
Axle/Gears: 3.73 posi
I have an 88 gta 305 i want to replace the injectors, i went on south bay, and it shows the injectors being 19lbs, is that big enough or should i go with 22lbs injectors.
Re: 19lbs injectors or bigger?
Im not stock, I have exhaust and headers and a little bit of head work done with a bigger throttle body, not really sure of all that would make a difference for injector size though
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
19 is fine... You will throw off the ECM if you put in 22's and don't tell it... It can adjust fuel within a certain degree, go with the 19's... I have a 305 TPI and bought my injectors form SouthBay too... no problems...
Rafael
Rafael
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
what Rafael said, even if you put in a bump stick it will not warrant larger injectors. Bosst wel thats a different story.
Car: 90 Iroc Vert
Engine: 5.0L
Yep - did 19# bosch III's - great stuff, car was rough, now its as smooth as silk, responsive and plenty of power.
thejimsterz28
Sep 15, 2015 04:37 PM
